Anyone having issues with Logix version 34? We had a L73S connected to the gateway at version 30 and upgraded the firmware to version 34 and now things don't seem too happy in the log's. Getting a lot of Read errors. Anyone seen this before?
ReadStructuredTagsRequest 11Jul2024 06:51:04 Uncaught Throwable: readerIndex(4) + length(48) exceeds writerIndex(6): CompositeByteBuf(ridx: 4, widx: 6, cap: 6, components=2)
java.lang.IndexOutOfBoundsException: readerIndex(4) + length(48) exceeds writerIndex(6): CompositeByteBuf(ridx: 4, widx: 6, cap: 6, components=2)
at io.netty.buffer.AbstractByteBuf.checkReadableBytes0(AbstractByteBuf.java:1442)
at io.netty.buffer.AbstractByteBuf.checkReadableBytes(AbstractByteBuf.java:1428)
at io.netty.buffer.AbstractByteBuf.readSlice(AbstractByteBuf.java:879)
at io.netty.buffer.SwappedByteBuf.readSlice(SwappedByteBuf.java:631)
at com.inductiveautomation.xopc.drivers.logix.requests.ReadStructuredTagsRequest.readStructuredTag(ReadStructuredTagsRequest.java:439)
at com.inductiveautomation.xopc.drivers.logix.requests.ReadStructuredTagsRequest.readTag(ReadStructuredTagsRequest.java:268)
at com.inductiveautomation.xopc.drivers.logix.requests.ReadStructuredTagsRequest.handleResponse(ReadStructuredTagsRequest.java:186)
at com.inductiveautomation.xopc.drivers.logix.requests.ReadStructuredTagsRequest.lambda$buildMultipleServicePacketService$2(ReadStructuredTagsRequest.java:117)
at com.digitalpetri.enip.cip.services.MultipleServicePacketService.decodeResponse(MultipleServicePacketService.java:70)
at com.digitalpetri.enip.cip.services.MultipleServicePacketService.decodeResponse(MultipleServicePacketService.java:18)
at com.digitalpetri.enip.cip.CipClient.lambda$invokeConnected$0(CipClient.java:71)
at java.base/java.util.concurrent.CompletableFuture.uniWhenComplete(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$UniWhenComplete.tryFire(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.postComplete(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.complete(Unknown Source)
at com.digitalpetri.enip.cip.CipClient$ConnectedDataHandler.itemsReceived(CipClient.java:270)
at com.digitalpetri.enip.cip.CipClient.onUnitDataReceived(CipClient.java:239)
at com.digitalpetri.enip.EtherNetIpClient.onChannelRead(EtherNetIpClient.java:196)
at com.digitalpetri.enip.EtherNetIpClient.access$900(EtherNetIpClient.java:50)
at com.digitalpetri.enip.EtherNetIpClient$EtherNetIpClientHandler.lambda$channelRead0$0(EtherNetIpClient.java:346)
