I am receiving the following alert in my diagnostic logs. As far as I can tell, the controller is not being disconnected and should not be timing out.
I started seeing this after I fixed a script that is logging data from PLC tags to a DB. More details available if needed, but this worked about 12 times before i started to see this log. Now the script has ran one more time but everytime it should be running, i see multiple logs with the details listed below:
java.util.concurrent.TimeoutException: senderContext=567728 timed out waiting 2000ms for response
at com.digitalpetri.enip.EtherNetIpClient.lambda$writeCommand$5(EtherNetIpClient.java:173)
at io.netty.util.HashedWheelTimer$HashedWheelTimeout.run(HashedWheelTimer.java:715)
at io.netty.util.concurrent.ImmediateExecutor.execute(ImmediateExecutor.java:34)
at io.netty.util.HashedWheelTimer$HashedWheelTimeout.expire(HashedWheelTimer.java:703)
at io.netty.util.HashedWheelTimer$HashedWheelBucket.expireTimeouts(HashedWheelTimer.java:790)
at io.netty.util.HashedWheelTimer$Worker.run(HashedWheelTimer.java:503)
