Hi all,
Requirement: Need single point control for the perspective sessions launched from Edge and Standard gateways.
I have 3 different gateways - 2 are Ignition Edge and 1 is standard Ignition. All 3 gateways have their own projects to control same set of PLC parameters and connected to each other in the network.
To avoid the more than single write/modify action on same PLC tag, I want to log out user from the older sessions and keep user logged in where it recently logged in to allow the write/modify actions.
Is there any way to make this work?
Thanks in advance!
