Long Save Time / Unable to Save
So i had imported a HEAP of project files onto a gateway as I was unable to upload to the gateway (Larger Than 21mb… Waiting on their IT department to change the settings so i can)…
So i imported the project files into a new project and attempted to save… (It does say saved but it hasnt)
  1. Anyone Beat my record time.
  2. Any suggestions?
How big is your project, and how slow is your network?
well its only 119mb of project files… Hosted in AWS Cloud so not slow at all.
119mB is a huge project - there’s not usually anywhere near that much content in a project.
You pretty much only hit large file sizes like that for one reason: serialized binary data.
Are you storing any images or other resources in the project in some way? Any large history binding datasets set to ‘Retain Rows’?
I did say it \ ( o o ) /
No large history bindings from memory.
I have just opened about 15 of the largest most complicated pages and it hasnt had any issues.
I am starting to think instead of trying to swallow the elephant i might be better suited to do one byte at a time
If this is 8.0.x, you could manually drop the appropriate files onto the filesystem of the gateway directly.
If it’s 7.9, you could try placing the .proj files on the local filesystem, then remoting in, launching a designer (on the gateway itself) and restoring the project?
Old Habits Die Hard
There's a reddit community called r/uptimeporn where people post pictures of how long their systems have gone without a reboot. On the surface, this thread looks like that, only [in all reality], it's pretty much the opposite :rofl:
