I have not done a lot of work on the FSQL side of things and should know how to do this, but I find I am having trouble getting it to work, so I figured I would get some expert advise.
I have a tag, that I am alerting on in Digital mode. It is when the machine is in automatic mode. I have it set to Any Change with the Ack Mode set to Auto. I see each event in the alert log, but the Active_time, Clear_time and Ack_time are all the same. The tag value is zero when not in automatic and 65535 when it is. How do set it so the Clear or Ack times are actually set to when the even changes back to zero from 65535 or back to 65535 from Zero?
My goal is then to be able to collect minutes from Clear_time - Active_time in my SQL query.
