Looking for Touch Panel to run Ignition
Hi, I’m looking for a touch panel, install Ignition and mysql and run it, or the other option is launch Ignition through a web browser on applet mode.
Can you tell me what kind of touch panel can run ignition? I don’t find much information about it.
I found this touch panel but I’m not sure it can run Ignition
https://www.phoenixcontact.com/online/portal/us?1dmy&urile=wcm%3apath%3a/usen/web/main/products/subcategory_pages/HMIs_for_HTML5_applications_P-07-02-02/87b3ac02-b749-4339-a067-30b33248fcfc
You’ll want a computer running some sort of operating system (e.g. Windows, Linux, etc) like this:
http://www.maplesystems.com/products/panel-pc/index_dk.htm
In my experience, it’s best to split the touchscreen HMI from the computer itself for maintenance purposes. The bits the users touch take more abuse. There are a number of solid state options out there that can be ‘bolted’ to the back of a commercial touchscreen if that’s the way you really want to go.
Teguar has some good systems, both touch screen for the client bit as well as headless units for the server.
Noax makes a good IP67 rated user interface as well.
I’ve run the Ignition client on Teguar. Haven’t tried on the Noax, but I’ve played with their hardware before and it is solid.
