Looping updates in a transaction question (execUpdate vs beginNamedQueryTransaction)
I’m using ignition 8.3 and have some questions about looping a few thousand update statements.
We found that some data was entered incorrectly and its easier to update the rows programaicly rather than doing them manually.
Looking into using transactions I noticed that the runNamedQuery is deprecated for execUpdate while beginNamedQueryTransaction is still available.
I planned on creating a screen that shows the updates for validation and then using a named query for the update statement, looping the result set in a transaction with beginNamedQueryTransaction and performing the updates in one fail swoop.
Is there any reason to use execUpdate or something different? Any suggestions or alternatives? Thanks!
I would recommend using execUpdate since it handles scoping better. This was a pain point for projects that used NamedQuery in gateway and client scopes. ExecUpdates’ default behavior handles this gracefully. Specifically, the optional project argument.
Manual link: system.db.execUpdate | Ignition User Manual
Excerpt:
Note: If no project is specified when run in the Gateway scope, an associated project or the Gateway scripting project will be used.
Essentially, in 8.3 runNamedQuery was split into three functions - execQuery, execUpdate, and execScalar. They do essentially the same thing as they previously did, it's just a bit easier to reason about. You still create transactions with beginNamedQueryTransaction and pass transactions to the functions in the same way. As @code_skin mentioned, a key reason for the new functions was the unfixable error in the function signature(s) of runNamedQuery across different scopes.
Thanks, mine will be called from the perspective session but will be executed from the gateway. Is one recommended over the other or does it just come down to scope? Thanks!
