Loss of Session Custom Properties in Perspective – Ignition 8.1.41
Hi everyone,
I'm currently working on a Perspective project using Ignition version 8.1.41, and I've run into an issue where session custom properties are being lost intermittently.
In my setup, I'm storing some important values under session.custom, but they occasionally disappear—especially after a refresh or navigating between views. These values are not being reset explicitly anywhere in the project, and I’ve double-checked that no scripts or bindings are modifying or clearing them unintentionally.
Has anyone else encountered this behavior in 8.1.41?
Is there something I might be missing regarding how session custom properties persist across views or sessions?
Any suggestions, best practices, or workarounds would be appreciated.
Thanks in advance!
@inductiveautomation1 @inductiveautomation2 @paul-griffith @cmallonee
Should have been fixed in 8.1.47
Thanks for the update.
I've had the same issue. This time even Session Props were wiped out from my project. One thing that helped me was that we have the project inherit settings from a template master, I opened the template master saved it and then all my properties came back without needing to restore back up.
