Hi I have a licensed ignition gateway on my site & I have connected to the existing machines via OPCUA.
I currently have Mitsubishi PLC’s and redlion CR3000 HMI’s (also acting as the OPCUA server at machine end)
The question I have is- if I want to take advantage of the vision client as a HMI on the machines as well… what is the easiest route?
Would I need an Edge license and touch panel PC to act as the HMI?- if so what license would I need
could I just use a raspberry pi with a touchscreen and add this to the machine? (Can I set a raspberry pi to autologon to a vision session and act as a HMI vision screen)
In the latter instance I would keep the redlion cr3000 in the panel to continue acting as a OPCUA server between ignition and the Mitsubishi PLC)
