I am currently working on a project for a machine learning manager exchange. In its configuration, it's necessary to specify a time range for the data retrieved from the tag. I’m curious if it’s possible to configure the machine learning model to run with real-time data from the tag, meaning it updates continuously.
It's currently not possible to configure a model to do this through the UI, but this example script should have the same effect by retraining/updating the model. I would recommend adding either a gateway timer or scheduled script to the MachineLearningManager resource set to run at whatever interval you want to update the model.
# Import
from exchange.ml.hook import (
tagHistory
, models
# Get the current time as the end date
endDate = system.date.now()
# Get the tag history data
trainingData = tagHistory.getTagHistory(
paths = ['Tag1', 'Tag2']
, startDate = system.date.addHours(endDate, -4)
, endDate = endDate
, returnSize = 300
, aggMode = 'Average'
, noInterpolation = True
, ignoreBadQuality = False
# Update the model
models.update(
modelID = 1
, name = 'Model'
, description = 'Model Description'
, model_type = 'regression'
, algorithm = 'OLSMultLinearRegression'
, args = [0]
, trainingData = trainingData
It's also worth noting that using a continuously trained model can have some unintended consequences. Where if the process that the model is being trained for starts to drift in a negative direction the model might not catch certain issues now that the process drift is included in the model's training data.
