Make elements transparent when mouse out of them
I have some buttons with the opacity set to 0.25
I want that if you hover the mouse the opacity is set to 1 so you can see clearly the buttons.
I tried this:
onMouseEnter:
	self.props.style.opacity = 1
onMouseLeave:
	self.props.style.opacity = 0.25
But the buttons for some reason blink (?).
Any idea?
Thx!
Do you have text on the button? I’m pretty sure that will trigger the onMouseLeave.
Do you have any other mouse events or bindings on your styles that are conflicting?
it was overlaping another component because I was trying negative margin and that was causing it. I changed it and now works correctly.
Thx for the help!
Mouse events are very unreliable because the scripting doesn’t run in the browser. You should use the Style Class “hover” state:
(let me finish your sentence)
... a reasonable amount of the time.
Take heed what Ryan mentioned. Keep graphical interactions in the client – eg through css (and JavaScript) – as much as practically possible, which includes hover events like this. They’re not only significantly faster and reliable, they don’t add unnecessary burdon on the gateway, thus increasing scalability and performance.
I did!
Now is also cleaner ^^
.psc-show_while_hover {
	opacity: 0.05;
	transition: opacity 0.25s ease;
	cursor: pointer;
.psc-show_while_hover:hover {
	opacity: 1.0;
