Make license permanent instead of leased
I know an older thread, but add another use case. I built an OBDII front end for my vehicle data with Arduino/Canbus/Modbus TCP. Works great, but having it timeout on the touchscreen in the vehicle is a bit of a pain, and don’t particularly want to be tethered to using a hotspot connection every time I’m in the vehicle.
I hope you aren't holding your breath. Maker is free. Turning it into a untethered license would spawn egregious abuse.
I’m sure it probably would….I’m guessing with a periodic internet connection, some metrics could be collected, although IA has said it’s not monitored, to expose abuse, so I understand the thought process. But one can always dream :slight_smile:
FWIW, I made a custom roof mount on my Suburban to hold and power my Starlink Mini. That would maintain your Maker connection pretty well, I think. :laughing:
I was planning to use the Maker edition for my house as a better and more reliable solution than home assistant. And I’m planning to use a Siemens PLS for lots of these things with bus controlled dimmers, heat pump and hydronic heating. Perspective would be a super solution for this use.
But an absolute requirement for me when doing anything with home automation is that it must work independent of a remote connected server.
Therefore, maker edition is not a viable option for smart homes. And a full license with perspective is of course out of normal people range for smart home control system.
Why is it a requirement?
Those who make elaborate requirements are bound to pay for the privilege. Free licenses for Ignition for Maker Edition is an incredible act of generosity from an entity that does not owe anyone anything for free.
Also keep in mind that it's just a license check and that all control is still local. So there's no concern with privacy of your data, but I still understand your concern that if you lose Internet for any reason for an extended period of time that you'd lose access to your home automation. That's why I still run home assistant as my primary home automation and only have Ignition as an additional toy I can play with.
I'll link this thread which has a few of my replies that cover this, but:
Disclaimer: I am just a dev
Our level of interest in B2C sales, as a company, rounds to zero. It's just not a market we're interested in. Maker is provided as a hook to get people to experiment with it and hopefully tell their bosses to buy Ignition at $workplace. That's not really a secret. If the licensing check in is a dealbreaker, then I would strongly encourage you to use a fully FOSS solution like HomeAssistant.
