I'm using WebDev to pipe my PyTorch detection data into tag locations but have been stuck for a few hours now.
I do not have the Compute module and I just found a post from another user who was encountering the same issue on a trial license.
I'm about to just scrap the idea of handling detection counts via scripts and setup a SQL db.
Ignition Log:
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 8, in doPost File "/usr/local/bin/ignition/user-lib/pylib/json/__init__.py", line 338, in loads return _default_decoder.decode(s) File "/usr/local/bin/ignition/user-lib/pylib/json/decoder.py", line 365, in decode obj, end = self.raw_decode(s, idx=_w(s, 0).end()) TypeError: expected string or buffer, but got
at org.python.core.Py.TypeError(Py.java:234)
at org.python.modules.sre.PatternObject.extractPyString(PatternObject.java:415)
at org.python.modules.sre.PatternObject.match(PatternObject.java:77)
at org.python.modules.sre.PatternObject$match_exposer.__call__(Unknown Source)
at org.python.core.PyObject.__call__(PyObject.java:477)
at org.python.core.PyObject.__call__(PyObject.java:481)
at json.decoder$py.decode$9(/usr/local/bin/ignition/user-lib/pylib/json/decoder.py:369)
at json.decoder$py.call_function(/usr/local/bin/ignition/user-lib/pylib/json/decoder.py)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyBaseCode.call(PyBaseCode.java:141)
at org.python.core.PyFunction.__call__(PyFunction.java:426)
at org.python.core.PyMethod.__call__(PyMethod.java:141)
at json$py.loads$4(/usr/local/bin/ignition/user-lib/pylib/json/__init__.py:351)
at json$py.call_function(/usr/local/bin/ignition/user-lib/pylib/json/__init__.py)
at org.python.core.PyBaseCode.call(PyBaseCode.java:126)
at org.python.core.PyFunction.__call__(PyFunction.java:416)
at org.python.pycode._pyx45.doPost$1(:31)
at org.python.pycode._pyx45.call_function()
at org.python.core.PyFunction.function___call__(PyFunction.java:474)
at org.python.core.PyFunction.__call__(PyFunction.java:469)
at org.python.core.PyFunction.__call__(PyFunction.java:464)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:847)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:829)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:868)
at com.inductiveautomation.webdev.gateway.handlers.PythonResourceHandler.doRequest(PythonResourceHandler.java:307)
at com.inductiveautomation.webdev.gateway.handlers.PythonResourceHandler.doPost(PythonResourceHandler.java:561)
at com.inductiveautomation.webdev.gateway.servlets.WebDevDispatch.doPost(WebDevDispatch.java:153)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:523)
at com.inductiveautomation.webdev.gateway.servlets.WebDevDispatch.service(WebDevDispatch.java:118)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1410)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1665)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:598)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1580)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1553)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
at org.eclipse.jetty.server.Server.handle(Server.java:563)
at org.eclipse.jetty.server.HttpChannel$RequestDispatchable.dispatch(HttpChannel.java:1598)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:753)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:501)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:287)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:421)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:390)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:277)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.run(AdaptiveExecutionStrategy.java:199)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
Caused by: org.python.core.PyException: TypeError: expected string or buffer, but got
... 77 common frames omitted
