I installed the maker edition of ignition with the intent of using it with my mqtt and zigbee2mqtt devices in HomeAssistant. When tried to install the MQTT engine it said it wasn’t available for the maker version. This seems like an issue that folks are not having but I don’t know where I am going wrong. I would appreciate any advice.
This may be related to the following 8.3 bug when using Docker related to the GATEWAY_MODULES_ENABLED environment variable.
If that doesn't fix it or you're not using Docker, I recommend reaching out to Inductive Support as from all I've seen, the MQTT modules should be available for Maker.
Also make sure you're using the MQTT module that's compatible with 8.3 because if you try to load an 8.1 module you'll get the same or very similar message.
