Hi all,
If I have a named query that query a daily total data for each location, how can I implement it into a bar chart?
Only worked if I have one row of data. If my set of data has more than 1 row data, it doesn't display the data.
Any suggestions? I have tried to transfer my date into millis but it still doesn't want to display the 2nd row data.
You are trying to do this with the Time Series Chart component.
Try the XY Chart instead.
I would set the xAxes.0.render : category to get evenly spaced bars.
Thanks for the reply Transistor.
Is there anyway I can stack 3 of them into 1 bar? I tried the xy chart but seems like separting into 3 bars is the only option
Use the XY Chart.
series.0.render : column
series.1.render : column
series.2.render : column
series.0.column.appearance.stacked : true
series.1.column.appearance.stacked : true
series.2.column.appearance.stacked : true
Make sure that
series.0.yAxis
series.1.yAxis
series.2.yAxis
all point to the same y-axis, otherwise they won't stack.
Oh man you saved me a lot of time.
Going to try this: Stacked Bar Chart in Perspective - Detailed Steps - Ignition - Inductive Automation Forum
But I guess no need anymore ![]()
Wait. It has same approach.
