Making Consolidated Messages from the alarm pipeline look pr
The the consolidate message generated does not look that nice. Is there any way to make the output an html e-mail or at least insert a carriage return between the alarms?
This:
3 alarm events have occurred: Alarm “Deviation Alarm” at “Primary Extruder - Zone 2” transitioned to Active at 11:17:11 Alarm “Deviation Alarm” at “Primary Extruder - Zone 4” transitioned to Active at 11:17:11 Alarm “Deviation Alarm” at “Primary Extruder - Zone 6” transitioned to Active at 11:17:11
to this:
Using this:
[code]{alarmEvents.Count} alarm events have occurred:
  • “{name}” on “{displayPath}” went into alarm at {eventTime|hh:mm:ss a}}}[/code]
I got this:
[code]7 alarm events have occurred:
  • “Deviation Alarm” on “Line 3 - Primary Extruder - Zone 1” went into alarm at 01:58:23 PM
  • “Deviation Alarm” on “Line 3 - Primary Extruder - Zone 2” went into alarm at 01:58:23 PM
  • “Deviation Alarm” on “Line 3 - Primary Extruder - Zone 3” went into alarm at 01:58:23 PM
  • “Deviation Alarm” on “Line 3 - Primary Extruder - Zone 4” went into alarm at 01:58:23 PM
  • “Deviation Alarm” on “Line 3 - Primary Extruder - Zone 5” went into alarm at 01:58:23 PM
  • “Deviation Alarm” on “Line 3 - Primary Extruder - Zone 6” went into alarm at 01:58:23 PM
  • “Deviation Alarm” on “Line 3 - Primary Extruder - Zone 7” went into alarm at 01:58:23 PM
    [/code]
    I can not find any documentation on the format of the consolidated e-mail string. Can someone point me to it?
I can’t see any either. Kevin Herron said in this post that the documentation was being completely written for 7.8. Hopefully this will be included!
You have to use html tags:
Modifying the default consolidated message would look like this:
<html>{alarmEvents.Count} alarm events have occured:<br>
{{Alarm “{label}” transitioned to {eventState} at {eventTime|hh:mm:ss}<br>}}
This gets you the following:
Alarm “Label for Alarm Test 1 Goes here” transitioned to Active at 12:12:39
Alarm “Label for Alarm Test 2 Goes here” transitioned to Active at 12:12:39
Alarm “Label for Alarm Test 3 Goes here” transitioned to Active at 12:12:39
This thread helped me with our SMS format for consolidation and wanted to share what we did.
  • Note - we are using the Twilio Module from IA. Not sure if there'd be a difference using other sms modules.
Expression Block
{alarmEvents.Count} alarm events have occurred.
Alarm - {eventTime|MMM dd, YYYY hh:mm:ss aa}
{displayPath}
