Ignition 8.1.28
In a managed tag provider, I try to create some Custom properties to my exposed tags.
For Boolean, I can do for example:
BasicBoundPropertySet realtimeProperty = new BasicBoundPropertySet();
realtimeProperty.set(new PropertyValue(new BasicProperty("test",Boolean.class),true));
ManagedTagProvider ourProvider = this.mapProvider.get(providerName);
ourProvider.configureTag(tagPath,realtimeProperty);
Types in Ignition dropdown: are:
I'm looking for the Java type to use for each one:
- Number => ???
- String=> String.class
- Boolean=> Boolean.class
- Array=> ???
- Document => com.inductiveautomation.ignition.common.document.Document.class
- Dataset => com.inductiveautomation.ignition.common.BasicDataset.class
Moreover, I need to pass the value of those custom properties from a script function.
values for the customs properties will be pass from Ignition to a script function to my module with something like:
protected void configureTagImpl(PyArgumentMap args) {
List<String> customNames = (List<String>) args.getArg("customNames", null);
List<String> customTypes = (List<String>) args.getArg("customTypes", null);
List<Object> customValues = (List<Object>) args.getArg("customValues", null);
For Boolean and String, no special conversion are needed but what is the best way to pass "Document" and "Array" from Ignition to the module script function ? in order to use it to feed the value of a tag custom propertie ?
