Manual Gateway Backup timeout using Chrome/Edge works on Firefox
I just upgraded to Ignition Gateway version 8.1.15.
I want to take a manual backup of the gateway.
For some reason when I click on the Download Backup button, I get a Failed - network error timeout.
This occurs using Google Chrome and Microsoft Edge, but it works fine with Firefox.
Is this just me or are others experiencing this problem ?
Surely this is a typo an you really mean 8.1.15 or 8.1.16?
How big is the backup file you end up with?
Oops. Yes I meant 8.1.15.
The backup file is 24,909 kB.
Hmm. Not large by any means. I think you may be the only one experiencing this, though I don’t know why…
Any errors in the Gateway logs after this happens? Is the gateway local or remote to you?
I’ve seen this before over really bad connections to the gateway (where the gateway home page takes 30+ seconds to load).
I have the same experience connecting locally and also from another computer.
Yes, there are errors in the gateway logs.
See below, newest entry is at the top:
Logger:Error, BackupServlet
Date Time: 2022-04-01 14:10:30
Message: Error creating gateway backup file
java.io.IOException: java.util.concurrent.TimeoutException: Idle timeout expired: 30002/30000 ms
at org.eclipse.jetty.util.SharedBlockingCallback$Blocker.block(SharedBlockingCallback.java:257)
at org.eclipse.jetty.server.HttpOutput.channelWrite(HttpOutput.java:270)
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:869)
at java.base/java.util.zip.DeflaterOutputStream.deflate(Unknown Source)
at java.base/java.util.zip.DeflaterOutputStream.write(Unknown Source)
at java.base/java.util.zip.ZipOutputStream.write(Unknown Source)
at com.inductiveautomation.ignition.gateway.servlets.BackupServlet.addFile(BackupServlet.java:267)
at com.inductiveautomation.ignition.gateway.servlets.BackupServlet.generateBackup(BackupServlet.java:151)
at com.inductiveautomation.ignition.gateway.servlets.BackupServlet.doBackup(BackupServlet.java:129)
at com.inductiveautomation.ignition.gateway.servlets.BackupServlet.doGet(BackupServlet.java:376)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1450)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1626)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1434)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1349)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:516)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:386)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
Caused by: java.util.concurrent.TimeoutException: Idle timeout expired: 30002/30000 ms
at org.eclipse.jetty.io.IdleTimeout.checkIdleTimeout(IdleTimeout.java:171)
at org.eclipse.jetty.io.IdleTimeout.idleCheck(IdleTimeout.java:113)
... 1 common frames omitted
Logger:Warning, HttpChannel
Message: /system/backup/partial
java.lang.IllegalStateException: ABORTED
at org.eclipse.jetty.server.HttpChannelState.sendError(HttpChannelState.java:915)
at org.eclipse.jetty.server.Response.sendError(Response.java:471)
at com.inductiveautomation.ignition.gateway.servlets.BackupServlet.doBackup(BackupServlet.java:132)
Logger: Info, InternalDatabase
Date Time: 2022-04-01 14:10:03
Message: Created auto-backup of internal database "config.idb" in 333 ms
Date Time: 2022-04-01 14:10:02
Message: Created auto-backup of internal database "config.idb"...
Date Time: 2022-04-01 14:09:44
