Map Component: Applying styles/properties to geoJSON data
I have a shaded region using geoJSON data on the map component I would like to toggle visibility on. My initial thought was to toggle the opacity of the feature on the map component but it does not change when I change any of the properties.
I generated the JSON data from geojson.io. Is there something I am missing?
A little late, but I ran into this issue and manually updated the property names to match what is required for Ignition.
For example, I changed:
"properties": {
        "stroke": "#0f3df5"
To:
"styleOptions": {
        "color": "#0f3df5"
However, I found the section in the Ignition Docs that walks through the process of Adding GeoJSON Shapes. Following these instructions will expedite the process.
Also, here is a related forum post, Importing KMS/KML data into ignition perspective Map using GeoJSON property
