Hi everyone,
I'm working with the Perspective Map component in Ignition and I'm looking for the best approach to implement security on different sections of a province.
I have a single province that is divided into four regions, with each region loaded as a separate GeoJSON file. These four GeoJSON files are combined on the map to display the complete province.
My goal is:
- Every user should be able to see the entire province on the map.
- Each user should only be able to view and interact with the pump stations located in the region(s) they have security access to.
- The other regions should remain visible as part of the province but should appear greyed out (for example, using a higher
fillOpacityor a different fill color) to indicate that they are outside the user's permissions. - Users should not be able to interact with pump stations in regions they don't have access to.
Any suggestion on how I can approach this ?
