Do anyone have experience mapping the ADVANTECH WISE-4012 to ignintion in order to read and write to its I/O?
Hello, I am also interested on this topic. Regards,
AM
check this linke may it will help you ..
http://advdownload.advantech.com/productfile/Downloadfile5/1-1L5RLLB/IAG_FAQ%20WISE-4000%20How%20to%20connect%20Mosquitto%20with%20iSensing%20MQTT_20190108.zip
According to the manual (Check out Appendix A.6 for your device) it supports Modbus TCP. Create a new device in the gateway using the Modbus TCP driver, in the hostname give it the IP address of your device, and you will be able to start reading registers from the device.
