I would like to duplicate this function available in tables to do the same in a report. Based on whether a value is within SP, put an image ( red X, green check ) based on a PASS or FAIL condition. Is this possible in V7.9 reports?
It is, though it’s not the most intuitive. If you truly need icons, then you’ll need to embed Image objects inside the table cells - and then use a keychain expression to choose which image key to reference based on some input data key.
