Mark components in template to not resize
Is there a way to mark components in a template so they will not change size when a template is resized?
I tried changing their layout to anchored, but there was no effect.
Thank you
I figured it out. there is a property inside the template called Enable Layout. By default it is disabled. When I enabled the property the anchored components did not resize.
