Markdown HTML Injection Not Populating with <script> Elements
Hey all,
I'm getting more into the webdev side of Perspective — working on a dynamic HTML table element with custom CSS styling using the advanced stylesheet — but I'm running into an issue when attempting to inject <script> elements into the DOM using a Markdown component's source property.
I can directly inject HTML and CSS into a view with this property, which I’m doing to generate a custom table; however, when I attempt to add in a <script> element and assign an onclick action to the <th> element to call a function within the <script> element to sort the table in asc/desc order, it seemingly gets ignored by the server parsing logic. I’m assuming this is intentional to avoid any sort of script injection via an input field from the UI side of the project - correct me if my understanding is wrong here.
Anyone have any tips?
Current function to populate the Markdown component's source property:
def build_html_table(inventory, percentages, forecast):
    html = """
<div class="psc-analysis-card-wrapper">
    <div class="psc-analysis-card-header">
        <div class="psc-analysis-title">
            <span class="psc-analysis-bar-icon"></span>
            <svg viewBox="0 0 24 24" width="2vh" height="2vh" xmlns="http://www.w3.org/2000/svg">
                <path d="M21,8c-1.45,0-2.26,1.44-1.93,2.51l-3.55,3.56c-0.3-0.09-0.74-0.09-1.04,0l-2.55-2.55C12.27,10.45,11.46,9,10,9 c-1.45,0-2.27,1.44-1.93,2.52l-4.56,4.55C2.44,15.74,1,16.55,1,18c0,1.1,0.9,2,2,2c1.45,0,2.26-1.44,1.93-2.51l4.55-4.56 c0.3,0.09,0.74,0.09,1.04,0l2.55,2.55C12.73,16.55,13.54,18,15,18c1.45,0,2.27-1.44,1.93-2.52l3.56-3.55 C21.56,12.26,23,11.45,23,10C23,8.9,22.1,8,21,8z" />
                <polygon points="15,9 15.94,6.93 18,6 15.94,5.07 15,3 14.08,5.07 12,6 14.08,6.93" />
                <polygon points="3.5,11 4,9 6,8.5 4,8 3.5,6 3,8 1,8.5 3,9" />
            </svg>
            Inventory Analysis
    <div class="psc-analysis-content">
        <div class="psc-analysis-overflow">
            <table id="inventoryAnalysisTable" class="psc-analysis-table">
                <thead class="psc-analysis-table-header">
                    <tr class="psc-analysis-table-header-row">
                        <th class="psc-align-text-left psc-padding sortable-header" onclick="sortTable(0)" style="cursor: pointer;">
                            Item ID
                            <span class="sort-indicator">&updownarrow;</span>
                        </th>
                        <th class="psc-align-text-right psc-padding sortable-header" onclick="sortTable(1)" style="cursor: pointer;">
                            Quantity Used
                        </th>
                        <th class="psc-align-text-right psc-padding sortable-header" onclick="sortTable(2)" style="cursor: pointer;">
                            Usage Rate (%)
                        </th>
                        <th class="psc-align-text-right psc-padding sortable-header" onclick="sortTable(3)" style="cursor: pointer;">
                            12-Week Forecast
                        </th>
                    </tr>
                </thead>
                <tbody class="psc-analysis-table-body">
    for product_line in ("PL01", "PL02"):
        for category in ("cat_a", "cat_b", "cat_c"):
            for item_id in sorted(inventory[product_line][category].keys()):
                used = inventory[product_line][category][item_id]
                rate = percentages[product_line][category][item_id]
                fcast = forecast[product_line][category][item_id]
                badge_class = (
                    "psc-analysis-badge lowpriority"
                    if rate < 4.2
                    else ("psc-analysis-badge mediumpriority" if rate < 8.4 else "psc-analysis-badge highpriority")
                html += """
<tr class="psc-light-bottom-border psc-hover-bg psc-duration-200">
    <td class="psc-analysis-table-cell psc-align-text-left psc-bold-font" data-sort="{0}">
        <span class="psc-analysis-badge">{0}</span> <span style="opacity:0.6;">({1}-{2})</span>
    </td>
    <td class="psc-analysis-table-cell psc-align-text-right psc-semibold-font" data-sort="{3}">{3}</td>
    <td class="psc-analysis-table-cell psc-align-text-right psc-bold-font" data-sort="{5}">
        <span class="{4}">{5:.1f}%</span>
    </td>
    <td class="psc-analysis-table-cell psc-align-text-right psc-bold-font" data-sort="{6}">{6}</td>
</tr>
                """.format(item_id, product_line, category.upper(), used, badge_class, rate, fcast)
    html += """
                </tbody>
            </table>
<style>
.sortable-header {
    position: relative;
    user-select: none;
.sortable-header:hover {
    background-color: rgba(0, 0, 0, 0.05);
.sort-indicator {
    font-size: 0.8em;
    margin-left: 5px;
    opacity: 0.5;
.sort-indicator.asc::after {
    content: '&uarr;';
    opacity: 1;
.sort-indicator.desc::after {
    content: '&darr;';
    opacity: 1;
</style>
<script>
function sortTable(columnIndex) {
    var table, rows, switching, i, x, y, shouldSwitch, dir, switchcount = 0;
    table = document.getElementById("inventoryAnalysisTable");
    switching = true;
    dir = "asc";
    var indicators = table.querySelectorAll('.sort-indicator');
    indicators.forEach(function(indicator) {
        indicator.className = 'sort-indicator';
    var currentIndicator = table.rows[0].cells[columnIndex].querySelector('.sort-indicator');
    while (switching) {
        switching = false;
        rows = table.rows;
        for (i = 1; i < (rows.length - 1); i++) {
            shouldSwitch = false;
            x = rows[i].getElementsByTagName("TD")[columnIndex];
            y = rows[i + 1].getElementsByTagName("TD")[columnIndex];
            var xValue = x.getAttribute('data-sort') || x.textContent || x.innerText;
            var yValue = y.getAttribute('data-sort') || y.textContent || y.innerText;
            if (columnIndex === 1 || columnIndex === 2 || columnIndex === 3) {
                xValue = parseFloat(xValue) || 0;
                yValue = parseFloat(yValue) || 0;
            } else {
                xValue = xValue.toLowerCase();
                yValue = yValue.toLowerCase();
            if (dir == "asc") {
                if (xValue > yValue) {
                    shouldSwitch = true;
                    break;
            } else if (dir == "desc") {
                if (xValue < yValue) {
                    break;
        if (shouldSwitch) {
            rows[i].parentNode.insertBefore(rows[i + 1], rows[i]);
            switching = true;
            switchcount++;
        } else {
            if (switchcount == 0 && dir == "asc") {
                dir = "desc";
                switching = true;
    currentIndicator.className = 'sort-indicator ' + dir;
</script>
    return html
You can get JavaScript to work if you place it in the onload attribute of a hidden image. I do that in my Markdown Editor+ component to capture the location of the cursor/selection:
def getCaretPositionJS(domID):
	return """<img style='display: none' src='/favicon.ico' onload="
		const view = [...window.__client.page.views._data.values()].find(view =>
			view.value.mountPath == this.parentNode.parentNode.parentNode.getAttributeNode('data-component-path').value.split('.')[0]).value;
		const notesTextArea = document.getElementById('""" + domID + """');
		var keepAlive""" + domID + """ = 0;
		var lastRunJS""" + domID + """ = -1;
		function getSelected() {
			const selectionStart = notesTextArea.selectionStart;
			view.custom.write('selectionStart', selectionStart);
			const selectionEnd = notesTextArea.selectionEnd;
			view.custom.write('selectionEnd', selectionEnd);
		function reportSelection() {
			setCursorAt = view.custom.read('setCursorAt');
			if (setCursorAt > -1) {
				notesTextArea.blur();
				notesTextArea.setSelectionRange(setCursorAt, setCursorAt);
				getSelected();
				notesTextArea.focus();
				view.custom.write('setCursorAt', -1);
			var runJS = view.custom.read('runJS');
			if (lastRunJS""" + domID + """ != runJS) {
				if (keepAlive""" + domID + """ % 100 == 0) {
					lastRunJS""" + domID + """ = runJS;
					view.custom.write('runJS', runJS + 1);
				keepAlive""" + domID + """ += 1;
				setTimeout(reportSelection, 100);
			else
				console.log('runJS shut down: """ + domID + """');
		notesTextArea.onclick = getSelected;
		notesTextArea.onkeyup = getSelected;
		notesTextArea.oncontextmenu = getSelected;
		notesTextArea.onmouseout = getSelected;
		view.custom.write('runJS', 0);
		reportSelection();
	"></img>"""
Ryan, this is such a crazy workaround - exactly what I needed to make the script functional for the table element. You're awesome!
