I am getting an error while trying to run a process segment using the Track and Trace module. Here is the code (with the segment name removed):
When I check the material lot 000000289, it lists its status as Complete and that it is Available as well.
Here is what the console shows when I get the Material lot and the core properties:
MaterialLot (25667638-b8eb-40f4-ac70-d00574ca9eee, 0000000289, 0 parents, 0 children, 1 custom properties, 0 complex properties)
{UUID=25667638-b8eb-40f4-ac70-d00574ca9eee, Name=0000000289, Description=, Enabled=true, Creator=Unknown, ResponseSegmentUUID=121c336c-b241-4efb-abd9-3c343ec9f5f7, MaterialRef=Response Material Definition, ___Material Definition Name Removed___, MaterialRefType=ResponseMaterialDef, MaterialRefUUID=486c95f8-a240-454c-ba75-238cbe71ad56, LotAssemblyType=null, LotStatus=Complete, LotLocationRef=Response Equipment, ___ Equipment Name Removed ___, LotLocationRefType=ResponseEquipment, LotLocationRefUUID=003346e9-48c0-4f9e-84bc-841aa2904e6b, LotUnits=null, LotSequence=1, LotAvailabilityStatus=Used}
Does anyone know how to resolve an error of this flavor?
16:32:49.631 [AWT-EventQueue-0] ERROR com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter - <HTML>Error executing script for event: <code><b>actionPerformed</b></code><BR>on component: <code><b>_____removed_____</b></code>.
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last):
File "<event:actionPerformed>", line 114, in <module>
File "<event:actionPerformed>", line 107, in run
File "<event:actionPerformed>", line 63, in run_transplant_segment
at com.sepasoft.production.common.model.mesobject.objects.segment.MESResponseSegment.internalSetMaterial(MESResponseSegment.java:533)
at com.sepasoft.production.common.model.mesobject.objects.segment.MESResponseSegment.setMaterial(MESResponseSegment.java:425)
java.lang.Exception: java.lang.Exception: Material lot number (0000000289) not found or it has already been used.
