I have a strange problem / issue
All the OPC Ua browser i used show me only two possible ways of using my node ids
1 - '[PLC]UDT_ACV_V1001.S_POS'
2 - '1:Devices.[PLC].Controller&:Global.UDT_ACV_V1001.S_POS'
But matlab can't directly acccess it..
In theory it should work like this
% Create OPC UA client object
uaClient = opcua("opc.tcp://localhost:62541");
% Connect the client to the OPC UA server
connect(uaClient);
nodeId = "ns=1;s=[PLC]UDT_ACV_V1001.LGC_CLS";
value = readValue(uaClient, nodeId );
disp(value);
disconnect(uaClient);
But this is not working...
Instead what I need to do is 3 times find by name..
DB_Node = findNodeByName(uaClient.Namespace, 'Devices', '-once');
ValvePointer = findNodeByName(DB_Node, 'UDT_ACV_V1001', '-once');
node = findNodeByName(ValvePointer, 'LS_CLS', '-once');
disp(node);
But it really slows down the performance..
Assuming that i will have to read thousands of signals.. Crazy enough!
Is there a way to make Ignition not to use brackets?
i suspect it to be a problem with [PLC]
if it would be PLC. - probably it would work
