Matrikon OPC UA Explorer do not represent values in the column Values until some settings you change and save. Just then all tags have values, like some kind of GI happens like on IEC104 and on change all signals have got their values but this should not be the case on OPC. Also not sure if related but this is happeneing on all servers that are linux OS based while one windows OS based do not have this kind of issue because as soon as I put wanted signals into the table on Matrikon OPC UA Explorer I have all values no need to wait for the values to be changed or setings to be saved to have all data like I have to do on linux OS based OPC server.
Also all data have values in ignition web interface OPC Quick Client no matter which OS based OPC server is.
anyone has similar issue that Matrikon Explorer shows only signals that are changing?
