Working with the Ignition SDK. I am admittedly not very experienced with Java or Maven build processes so issue I am running into is likely my lack of knowledge.
I have defined a client class for a device driver that I would like to implement within Ignition. My client class works as expected when I test through my terminal. I have implemented the ModuleHook and ManagedDevice interfaces as well as the DeviceType following the example:
I am trying to execute the mvn package step to create the .modl file. The packages will build and compile but when trying to package the modl i get the following error (i will put the full stack trace in the following comment):
Cannot invoke "java.util.List.iterator()" because the return value of "org.apache.maven.project.MavenProject.getCollectedProjects()" is null.
My project is structure as:
Device -
.\Device-build
..\pom.xml (this pom is where the modl goal is defined)
.\Device-device
..\pom.xml
.\pom.xml
Full stack trace:
automation.ignitionsdk:ignition-maven-plugin:1.1.0:modl failed: Cannot invoke "java.util.List.iterator()" because the return value of "org.apache.maven.project.MavenProject.getCollectedProjects()" is null -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.1.0:modl (default) on project MacnetDevic
e-build: Execution default of goal com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.1.0:modl failed: Cannot invoke "java.util.List.iterator()" because the return value of "org.apache.maven.project.MavenProject.getCollectedProjects()" is null
at org.apache.maven.lifecycle.internal.MojoExecutor.doExecute2 (MojoExecutor.java:333)
at org.apache.maven.lifecycle.internal.MojoExecutor.doExecute (MojoExecutor.java:316)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:212)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:174)
at org.apache.maven.lifecycle.internal.MojoExecutor.access$000 (MojoExecutor.java:75)
at org.apache.maven.lifecycle.internal.MojoExecutor$1.run (MojoExecutor.java:162)
at org.apache.maven.plugin.DefaultMojosExecutionStrategy.execute (DefaultMojosExecutionStrategy.java:39)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:159)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:105)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:73)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build (SingleThreadedBuilder.java:53)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute (LifecycleStarter.java:118)
at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:261)
at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:173)
at org.apache.maven.DefaultMaven.execute (DefaultMaven.java:101)
at org.apache.maven.cli.MavenCli.execute (MavenCli.java:906)
at org.apache.maven.cli.MavenCli.doMain (MavenCli.java:283)
at org.apache.maven.cli.MavenCli.main (MavenCli.java:206)
at jdk.internal.reflect.DirectMethodHandleAccessor.invoke (DirectMethodHandleAccessor.java:103)
at java.lang.reflect.Method.invoke (Method.java:580)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced (Launcher.java:283)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch (Launcher.java:226)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode (Launcher.java:407)
at org.codehaus.plexus.classworlds.launcher.Launcher.main (Launcher.java:348)
Caused by: org.apache.maven.plugin.PluginExecutionException: Execution default of goal com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.1.0:modl failed: Cannot invoke "java.util.List.iterator()" because the return value of "org.apache.maven.project.MavenProject.getCollectedProjects()" is null
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo (DefaultBuildPluginManager.java:133)
at org.apache.maven.lifecycle.internal.MojoExecutor.doExecute2 (MojoExecutor.java:328)
Caused by: java.lang.NullPointerException: Cannot invoke "java.util.List.iterator()" because the return value of "org.apache.maven.project.MavenProject.getCollectedProjects()" is null
at com.inductiveautomation.ignitionsdk.IgnitionModlMojo.execute (IgnitionModlMojo.java:161)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo (DefaultBuildPluginManager.java:126)
I think you'll need to share the pom.xml contents from your build module.
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
<modelVersion>4.0.0</modelVersion>
<parent>
<groupId>com.lyten</groupId>
<artifactId>MacnetDevice</artifactId>
<version>1.0.0-SNAPSHOT</version>
<relativePath>../pom.xml</relativePath>
</parent>
<artifactId>MacnetDevice-build</artifactId>
<dependencies>
<dependency>
<artifactId>MacnetDevice-device</artifactId>
<scope>compile</scope>
</dependency>
</dependencies>
<build>
<plugins>
<plugin>
<groupId>com.inductiveautomation.ignitionsdk</groupId>
<artifactId>ignition-maven-plugin</artifactId>
<version>1.1.0</version>
<executions>
<execution>
<phase>package</phase>
<goals>
<goal>modl</goal>
</goals>
</execution>
</executions>
<configuration>
<projectScopes>
<projectScope>
<name>MacNetDevice</name>
<scope>G</scope>
</projectScope>
</projectScopes>
<moduleId>com.lyten.MacnetDevice</moduleId>
<moduleName>MacNetDevice</moduleName>
<moduleDescription>${project.description}</moduleDescription>
<moduleVersion>1.0-SNAPSHOT</moduleVersion>
<requiredIgnitionVersion>8.0.0</requiredIgnitionVersion>
<depends>
<depend>
<scope>G</scope>
<moduleId>com.inductiveautomation.opcua</moduleId>
</depend>
</depends>
<hooks>
<hook>
<scope>G</scope>
<hookClass>com.lyten.macnet.MacNetDeviceModuleHook</hookClass>
</hook>
</hooks>
</configuration>
</plugin>
</plugins>
</build>
</project>
Admittedly its mostly just a copy paste rename things from the example.
Hmm, looks okay.
What directory are you executing mvn package from? Should be the root.
that was the issue I was trying to package the MacNetDevice-build module directly. as I suspected my lack of understanding. Thank you for the quick responses!
