Hello Kevin. I'm Victor's co-worker, He can't respond right now.
We tried to add a new device and this is the log entry showed in the console:
9:33:02 RecordEditForm Error updating Device "CT3_CN3_1".
simpleorm.utils.SException$Jdbc: Executing INSERT INTO DeviceSettings (DeviceSettings_ID, Name, Type) VALUES (?, ?, ?)
for [DeviceSettingsRecord 377 NewRecord Dirty0]
at simpleorm.sessionjdbc.SSessionJdbcHelper.flushExecuteUpdate(SSessionJdbcHelper.java:409)
at simpleorm.sessionjdbc.SSessionJdbcHelper.flush(SSessionJdbcHelper.java:376)
at simpleorm.sessionjdbc.SSessionJdbc.flush(SSessionJdbc.java:436)
at simpleorm.sessionjdbc.SSessionJdbc.flush(SSessionJdbc.java:421)
at simpleorm.sessionjdbc.SSessionJdbc.commitAndDetachDataSet(SSessionJdbc.java:362)
at com.inductiveautomation.ignition.gateway.web.components.RecordEditForm.commitRecords(RecordEditForm.java:433)
at com.inductiveautomation.ignition.gateway.web.components.RecordEditForm.onSubmit(RecordEditForm.java:383)
at com.inductiveautomation.ignition.gateway.web.components.RecordEditForm.onSubmit(RecordEditForm.java:350)
at com.inductiveautomation.ignition.gateway.web.components.RecordEditForm$1.onSubmit(RecordEditForm.java:125)
at org.apache.wicket.markup.html.form.Form$9.component(Form.java:1248)
at org.apache.wicket.markup.html.form.Form$9.component(Form.java:1242)
at org.apache.wicket.util.visit.Visits.visitPostOrderHelper(Visits.java:274)
at org.apache.wicket.util.visit.Visits.visitPostOrder(Visits.java:245)
at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1241)
at org.apache.wicket.markup.html.form.Form.process(Form.java:923)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:769)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:702)
at sun.reflect.GeneratedMethodAccessor59.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:216)
at
org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:
240)
at
org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:226)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:814)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:253)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:210)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:281)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:188)
at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:245)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:581)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1156)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1088)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:119)
at org.eclipse.jetty.server.Server.handle(Server.java:517)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:306)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:242)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:245)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:75)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:213)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:147)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
at java.lang.Thread.run(Unknown Source)
Caused by: java.sql.SQLException: [SQLITE_CONSTRAINT] Abort due to constraint violation (UNIQUE constraint failed:
DEVICESETTINGS.DEVICESETTINGS_ID)
at org.sqlite.core.DB.newSQLException(DB.java:890)
at org.sqlite.core.DB.newSQLException(DB.java:901)
4/11/22, 9:33 Ignition : SCADA Crucero
localhost:8088/main/web/config/system.console?141 3/3
at org.sqlite.core.DB.execute(DB.java:810)
at org.sqlite.core.DB.executeUpdate(DB.java:847)
at org.sqlite.jdbc3.JDBC3PreparedStatement.executeUpdate(JDBC3PreparedStatement.java:86)
at
com.inductiveautomation.ignition.gateway.localdb.DelegatingDataSource$DelegatingConnection$DelegatingPreparedStatemen
t.executeUpdate(DelegatingDataSource.java:584)
at simpleorm.sessionjdbc.SSessionJdbcHelper.flushExecuteUpdate(SSessionJdbcHelper.java:407)
After this error, the device is not added to Ignition and we can't add any other device, no matter the driver used (we tried with Siemens driver and get the same error)
This is the parameters of the new Modbus device shown in the log entry we are try to add. Ignition _ SCADA Crucero.pdf (179.4 KB)
{ If this is truly an Ignition bug, your customer is either going to just live with it, or pay to reinstate support. And it certainly looks like an Ignition bug, to me. }
