Hello,
I am having some issues on a redundant gateway setup with the child gateway failing to ping the master gateway occasionally, and I believe that the network is not causing the issue. When I look at the performance I can see that for some reason the gateway is convinced that it only has 1 thread available to it in the Memory Trend, however you can see the Memory max heap is 2048 near its gauge.
I am curious if anyone has any ideas what this means, if they have seen it, or potentially I have something configured incorrectly.
(ignition.conf is set to 2048 as well)
