By referring to the vision template, when I launch the project, all components able to maximize until the left side of the screen but even I add in a 'label' parallel down with the template label, the newly add label will stay in the center of screen. Is that any trick or properties I missed out in order to let the newly add label to shift to the left of screen when I launch the project?
Vision has "Layout" properties for every component and container. You need to be consistent. It looks like you are mixing "relative" layout with "left anchored" layout.
