When making a call to system.util.invokeAsynchronous system.util.invokeAsynchronous(app.tagmgmt.updateTagConfigurationsProcedure)
I pass a jython method to this that calls a stored
procedure in the database
def updateTagConfigurationsProcedure():
import system
import app.tagmgmt
#txId = system.db.beginTransaction(timeout=120000)
try:
query = ‘CALL UpdateTagCategories()’
try:
tagsUpdated = system.db.runUpdateQuery(query)
#tagsUpdated = system.db.runUpdateQuery(query, tx=txId)
#system.db.commitTransaction(txId)
pass
except Exception, e:
print “Update Tags error” , e
#system.db.rollbackTransaction(txId)
pass
app.tagmgmt.updateIgnitionTagProvider()
finally:
#system.db.closeTransaction(txId)
pass
and lastly an RPC call to a method inside of our tag provider.
def updateIgnitionTagProvider():
try:
import betagprovider
betagprovider.loadTagdef()
pass
Somewhere in this call I get the error in the subject line. Here is the complete error:
Update Tags error maximum recursion depth exceeded. Where is this error thrown from as I’m not aware of in recursive methods in our tagprovider.
This kind of thing most often happens in the propertyChange event script.
You never mentioned where the code was that implemented this script.
The script is called from the click event of a button on the HMI. In the handler the button has a field that holds the data from a table and passes that to the script. At the beginning of the routine the data is converted to a pyDataSet and iterated through to update a table in the database.
app.tagmgmt.applyTagDefinition( event.source.parent.getComponent(‘Table’).data )
system.db.refresh( event.source.parent.getComponent(‘Table’), ‘data’ )
When it gets to this section of the code the flow is pretty obvious.
Call UpdateTagCategories is a stored procedure that is updates tables that correspond to the scan class.
The call to the betagprovider.loadtagdef is a method that loads all active scan class for screen updating. If you would like to see the loadtagdef RPC you can see the post at:http://www.inductiveautomation.com/forum/viewtopic.php?f=74&t=11053
It looks like these two functions are calling each other?
[code]
public String loadTagdef() throws Exception {
return (String) invoke(loadTagdef(m_provider).toString(), new Serializable[] {m_provider});
@Override
public String loadTagdef(String provider) throws Exception {
return (String) invoke(“loadTagdef”, new Serializable[]{provider});
}[/code]
Do you have an actual stack trace reported from this error? You might need to turn on the client console from the Java control panel.
Regards,
I have not been able to get a stack trace from this. I will turn it on in Java console and go from there. Additionally, on a side note, is there a cap on number of modules that can be signed in a given period.
I was looking for how to log the stack trace earlier today and can across this traceback but I didn’t get a chance to mock/test it:
http://docs.python.org/2/library/traceback.html
If you comment-out or remove the try except blocks in your code, you’ll get the stack trace in the console.
RuntimeError: maximum recursion depth exceeded
at org.python.core.Py.RuntimeError(Py.java:145)
at org.python.core.Py.JavaError(Py.java:476)
at org.python.core.Py.JavaError(Py.java:474)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:188)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:204)
at org.python.core.PyObject.call(PyObject.java:441)
at org.python.core.PyObject.call(PyObject.java:447)
at org.python.core.PyMethod.call(PyMethod.java:154)
at org.python.pycode._pyx69.f$0(event:cellEdited:2)
at org.python.pycode._pyx69.call_function(event:cellEdited)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1261)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:539)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:155)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:266)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at com.sun.proxy.$Proxy20.cellEdited(Unknown Source)
at com.inductiveautomation.factorypmi.application.components.PMITable.fireCellEditedEvent(PMITable.java:2076)
at com.inductiveautomation.factorypmi.application.components.PMITable$DataSetTableModel.setValueAt(PMITable.java:2061)
at com.inductiveautomation.factorypmi.application.components.PMITable.setValue(PMITable.java:2109)
at com.inductiveautomation.factorypmi.application.components.PMITable.setValue(PMITable.java:2114)
at sun.reflect.GeneratedMethodAccessor110.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:186)
at
atcom.inductiveautomation.factorypmi.application.components.PMITable.setValue(PMITable.java:2109)
atcom.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:539)
You’ve got some infinite (or may as well be) recursion in your scripting calls.
Maybe whatever you’re doing in your script that triggers a cell update needs to happen in an invokeLater() call?
Yes, to clarify what Kevin is saying: in this stack, it looks like you have an event script defined for “cell edited”. In your script, you’re modifying the contents of the table, in turn firing another cell edit event. You can get around this by scheduling your edit to happen a tiny bit of time later, outside of your event script, using [tt]system.util.invokeLater[/tt]. For example:
#current event script code here
#calculating things...
newData = something_to_get_data
def updateFunc(data = newData, table = table):
#do update stuff here
system.util.invokeLater(updateFunc)
So, you define a function inline and then invoke it. When it’s called, it won’t have any of the variables in scope that you had, so you have to “pass” in any that you need as default parameters in the function definition.
Hope that helps,
