We have been experience a functional Lockout on our clients because there is a loss connection between our database and the Ignition Gateway. This seems to cause a memory leak on the client. So I took a few screen shots to show the functional lockout and what I am seeing.
As for why the database if faulting I still cant figure out why it faults. All quarries take less then 1 second per request and no more then 5 or 6 connections are used at a time. Bandwidth does not seem to be an issue because each database read/write seems instantaneous monitoring from the server side I/O.
Has anyone experienced this issue or have an idea to point me in the right direction?
Img Hosting by postimg.org/
Memory Before Lockout:
Lockout Sync:
Memory During Lockout:
Memory After Lockout End:
Exception: Error running query:
SQLQuery(query=select FJ1shifttotal from tblfjrejectcodes where rejectcode = 2, database=WCMelody)@500ms
On: FJ_Rejects.Root Container.2.value
caused by GatewayException: Connection Error: Cannot get a connection, pool error Timeout waiting for idle object
caused by SQLNestedException: Cannot get a connection, pool error Timeout waiting for idle object
Ignition v7.7.4 (b2015033012)
Java: Oracle Corporation 1.7.0_45
