I want the memory tag to count from 1 to 1200 when the one button is clicked in View A. This memory tag will be binded to label component in View B.
I tried to execute this in memory tag, but not working,
counter = system.tag.readBlocking(["[~]counter_tag"])
counter = counter + 1
system.tag.writeBlocking(["[default]My/Tag/counter"],["counter"])
Read blocking will return a list of tag objects, to get the value of the first (and only) tag you should
counter = system.tag.readBlocking(["[~]counter_tag"])[0].value
if counter >= 1200:
counter = 1
else:
counter += 1
system.tag.writeBlocking(["[default]My/Tag/counter"],[counter])
You also seem to be writing a string as the value, and not the variable counter
Thank you for your reply. Need a clarity how it will update continuously when I click one button in View A.
A computer can count from 1 to 1200 EXTREMELY fast... It's likely you won't see anything but 1200.
Do you want to count 1200 seconds?
Do you want this to be on a per-client basis? i.e. each client can have a different timer?
If global, you want to set the datetime you press the button in a memory tag, then in an expression memory tag, use the expression:
if(isNull({date/tag}), -1, secondsBetween({date/tag}, now(1000))) // these might be the wrong way around, I always swap them...
To stop it, use an on value change event on the counter tag to set the date tag value to None if its value is > 1200. If you want it to reset after 1200 that is.
If you want it client based, I'd use sessions props to do the same thing
Thankyou for your reply. Will workout and update
This and your other timer questions should really be handled by the PLC. I think you are building a fragile system that will break.
I didn't see the other timer questions, but if this is for control, certainly what @Transistor says is a must. SCADA is not for process control logic
