Good morning,
I'm working on a project where I need to check which item in the MenuTree was clicked. Using event.path, I have the item's index, but when I try to use it in an if statement to trigger an action, nothing happens.
Here's the code:
def runAction(self, event):
clicked_item_path = event.path
if clicked_item_path == [0,1]:
self.getSibling("EmbeddedView").props.path = "View_Moldeo_L1"
Make sure you use the onItemClicked event. Then you can do something like this:
if event.enabled: # check if item is enabled
self.getSibling("EmbeddedView").props.path = event.label
# or if you need custom view paths #
clicked_item = event.label.lower()
if clicked_item == "some_string":
view = "View_Moldeo_L1"
elif clicked_item == "some_other_string":
view = "View_Moldeo_L2"
else:
return
self.getSibling("EmbeddedView").props.path = view
The method you mentioned worked.
Thanks, Hayes.
If you did need the full path for some reason, it seems the path value is a pyArray. You might need to cast it to a list for comparison.
if list(event.path) == [0,1]:
