MenuTree flex-basis:auto results in 0px component
I am trying to use a MenuTree component in a flex container with a flex-basis of auto.
When I do this the menu is rendered with 0 height. I've had a quick play with the CSS and can't seem to trick any of the DOM elements to understand the content dimentions.
To replicate create a view with a flex root type. Add a menuTree component and set basis to auto. It should disappear. What I would expect is that it resizes to the required height to render the elements inside it.
Here is the JSON for a view setup already.
Any ideas?
  "custom": {},
  "params": {},
  "props": {},
  "root": {
    "children": [
        "meta": {
          "name": "MenuTree"
        "position": {
          "shrink": 0
        "props": {
          "items": [
              "backActionText": "",
              "enabled": true,
              "items": [
                  "enabled": true,
                  "items": [],
                  "label": {
                    "icon": {
                      "path": ""
                    "text": "Submenu item 1"
                  "navIcon": {
                    "path": ""
                  "resetOnClick": false,
                  "showHeader": true,
                  "style": {
                    "classes": ""
                  "target": "",
                  "visible": true
                  "enabled": true,
                  "items": [],
                  "label": {
                    "icon": {
                      "path": ""
                    "text": "Submenu item 2"
                  "navIcon": {
                    "path": ""
                  "showHeader": true,
                  "style": {
                    "classes": ""
                  "target": "",
                  "visible": true
              "label": {
                "icon": {
                  "path": "material/list"
                "text": "Menu Item 1"
              "navIcon": {
                "color": "",
                "path": "material/chevron_right"
              "showHeader": true,
              "style": {
                "classes": ""
              "target": "",
              "visible": true
              "enabled": true,
              "items": [
                  "enabled": true,
                  "items": [],
                  "label": {
                    "icon": {
                      "path": ""
                  "navIcon": {
                    "path": ""
                  "showHeader": true,
                  "style": {
                    "classes": ""
                  "target": "",
                  "visible": true
                  "enabled": true,
                  "items": [],
                  "label": {
                    "icon": {
                      "path": ""
                  "navIcon": {
                    "path": ""
                  "showHeader": true,
                  "style": {
                    "classes": ""
                  "target": "",
                  "visible": true
              "label": {
                "icon": {
                "text": "Menu Item 2"
              "navIcon": {
                "color": "",
              "showHeader": true,
              "style": {
                "classes": ""
              "target": "",
              "visible": true
        "type": "ia.navigation.menutree"
    "meta": {
      "name": "root"
    "props": {
      "direction": "column"
    "type": "ia.container.flex"
