Merge 2 dataset in to single dataset
Hi
i have 2 dataset and i want to merge 2 dataset in to single dataset
which is the easiest way to do it?
1 dataset have 3 columns
2 dataset have 2 columns
i want final out with single dataset with 200R*5C
Use system.dataset.addColumn() in conjunction with the getColumnAsList() function on the dataset to add the columns from one dataset to the other.
Tired below code but getting error
columnData = []
ds1  = event.source.parent.getComponent('Power Table').data
ds2 = event.source.parent.getComponent('Power Table 1').data
col_name = ds2.getColumnNames()
col_type = ds2.getColumnTypes()
colCount = ds2.getRowCount()
for i in range(ds2.getColumnCount()):
 	columnData = ds2.getColumnAsList(i)
	ds2 = system.dataset.addColumn(ds1, colCount, columnData, col_name[i], col_type[i])
error:
TypeError: addColumn(): 3rd arg can't be coerced to org.python.core.PySequence
	at org.python.core.Py.TypeError(Py.java:236)
	at org.python.core.PyReflectedFunction.throwError(PyReflectedFunction.java:213)
	at org.python.core.PyReflectedFunction.throwBadArgError(PyReflectedFunction.java:316)
	at org.python.core.PyReflectedFunction.throwError(PyReflectedFunction.java:325)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:171)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:208)
	at org.python.core.PyObject.__call__(PyObject.java:433)
	at org.python.core.PyObject.__call__(PyObject.java:437)
	at org.python.pycode._pyx833.f$0(<event:mouseClicked>:12)
	at org.python.pycode._pyx833.call_function(<event:mouseClicked>)
	at org.python.core.PyTableCode.call(PyTableCode.java:173)
	at org.python.core.Py.runCode(Py.java:1687)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:788)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:206)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:299)
	at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
	at com.sun.proxy.$Proxy57.mouseClicked(Unknown Source)
	at java.desktop/java.awt.AWTEventMulticaster.mouseClicked(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: org.python.core.PyException: TypeError: addColumn(): 3rd arg can't be coerced to org.python.core.PySequence
	... 49 common frames omitted
You should use code similar to this:
for i, name in enumerate(ds2.columnNames):
    ds1 = system.dataset.addColumn(ds1,ds1.columnCount,list(ds2.getColumnAsList(i)),name,ds2.getColumnType(i))
