I haven’t used a merge before but I would typically handle this kind of functionality with a stored procedure.
Stored procedure would take the 2 parameters so your named query would resemble this
EXEC dbo.spName :param1 :param2
Then the stored procedure would resemble this (rough sample)
The text formatting tool got mad about some of the code but it’s a basic create procedure statement with parameters of: @UserID INT, @UserName VARCHAR(128)
IF NOT EXISTS (SELECT TOP 1 COUNT(*) FROM tblUsers WHERE UserId = @UserId)
INSERT INTO tblUsers (UserId, UserName)
VALUES (@UserId, @UserName)
ELSE
UPDATE tblUsers
SET UserName = @UserName
WHERE UserID = @UserId
Edit:
I forgot a where clause on my update. I wrote this in a query window without having any tables and stuff so I didn’t test it. I would recommend testing yours on a test system since it’s using an update statement.
I used MERGE to INSERT or UPDATE in named queries at a prior company and they worked great.
I don’t have access to them to provide as a sample.
Validate the query with your database tool (looks like MSSMS for you, SQL Developer, PGAdmin, etc.) or even in the Designer Tools–>Database Query Browser, before you dump it into the Named Query.
You were correct, my syntax was invalid. The block below works with the Ignition Named Query with Parameters. Thank you Lynn.
MERGE INTO dbo.table WITH (HOLDLOCK) AS target
USING (Select
:Val1 as Val1
,:Val2 as Val2
,:Val3 as Val3
,:Val4 as Val4
,:Val5 as Val5
) as source
ON ( target.Val1= source.Val1
AND target.Val2 = source.Val2
AND target.Val3 = source.Val3)
WHEN MATCHED THEN
UPDATE SET
target.Val4= source.Val4,
target.Val5 = source.Val5,
WHEN NOT MATCHED THEN
INSERT
(Val1
,Val2
,Val3
,Val4
,Val5
VALUES
(:Val1
,:Val2
,:Val3
,:Val4
,:Val5
