Merging alarm journals from two systems?
Hello,
We have two independent systems; where only one is considered the system of record at any given time. Since they behave as independent systems they have their own alarm journals.
Is there a way to merge two alarm journals into a single table for analytics? Some of out initial ideas:
  • use a script to scrape the journals from both systems and save it into a single table.
  • add a new journal to both systems that point to same database/table. (Not sure if there would be collisions between the gateways though)
Open to thoughts on alternative methods?
Same database just different tables? You should be able to query across both. I doubt that you could use the alarm journal viewer but you should be able to do a report etc…
Edit: original reply via phone. Fixed grammer
