I am attempting to load metrics information using Sepasoft’s MES 1.0, and I get the following error from the results:
“[Run] Exception executing analysis provider. null”
I’m not sure what this means, as there is no actual message here telling me what is wrong. Has anyone seen this before?
Code
startDate = system.date.setTime(system.date.getDate(2022, 7, 17), 23, 0, 0)
endDate = system.date.setTime(system.date.getDate(2022, 7, 18), 22, 59, 59)
settings = system.production.utils.createAnalysisSettings()
settings.setAnalysisProvider('Run')
settings.addFilter('Start Date', system.db.dateFormat(startDate, 'yyyy-MM-dd HH:mm:ss'))
settings.addFilter('End Date', system.db.dateFormat(endDate, 'yyyy-MM-dd HH:mm:ss'))
settings.addCompareBy('Line')
settings.addCompareBy('Shift')
settings.addDataPoint('Date')
settings.addDataPoint('Product Code')
settings.addDataPoint('Line Infeed Count')
settings.addDataPoint('Line Production Count')
settings.addDataPoint('Line Standard Count')
settings.addDataPoint('Line Standard Rate')
settings.addDataPoint('Line Standard Rate Period')
settings.addDataPoint('Run Down Time')
settings.addDataPoint('Run Planned Down Time')
settings.addDataPoint('Run Elapsed Time')
settings.addDataPoint('Run Time')
settings.addDataPoint('OEE Quality')
settings.addDataPoint('OEE Performance')
settings.addDataPoint('OEE Availability')
settings.addDataPoint('OEE')
if settings.hasError():
print 'Error: %s' % settings.getErrorMessage()
results = system.production.utils.getAnalysisResults(settings)
if results.hasError():
print 'Error: %s' % results.getErrorMessage()
data = results.getTableResults()
