MES is a module that works directly with Ignition and is not stand alone. The MES module leverages all the power and features of Ignition.
Cells are the individual machines or manufacturing equipment that you want to monitor.
The manual is available online from the download section of the website.
Please download and install Ignition with the MES module and you can run in trial mode. The trial mode has all the features available but will timeout in two hours (it can easily be reset).
I just want to verify - if I want the OEE module, what do I have to buy to have the Ignition ‘platform’? Is The Works required? Or can I buy a different module that would install the “Ignition Core Modules” prerequisite? (Vision?)
Thank you!!!
