Having the report manager in the Gateway now is much welcomed. For those of us that use the MES modules How can we use the Analysis Controllers as a data source for the reports?
Hi JP,
The MES analysis data can be returned via script that you can use in a “Script” datasource.
The attached PDF will show you the methods and an example.
Regards,
Pete Low
MES Development
MES Analysis via script.pdf (74.5 KB)
Sweet! I did check the manual before posting. Is that info missing from the manual?
JP
Pete,
Do you have an example like this on how to script a Pareto from the SPC/Quality module?
Hi Pete, would you be able to provide this script? The link has expired.
Nigel
Sepasoft has some good examples in their manual:
OEE 2.0
https://help.sepasoft.com/docs/display/MHD/system.mes.analysis.createMESAnalysisSettings
OEE 1.0
https://help.sepasoft.com/docs/display/STT/system.production.createAnalysisSettings
Thanks for your help Pete, much appreciated, we got it in the end
