Hello,
I have 2 edge gateways and 100+ devices connected to a read/write/edit gateway. This read /write/ edit gateway is connected to a read only gateway which is an interface with a couple APIs.
for the 100+ devices that are using Standard Tag Providers, it is easy for me to use a message handler that reaches out to the read only server and and delivers a payload using message handler.
With the 2 edge HMIs, I cannot allow traffic initiated by the edges through the read /write/ edit gateway.
Is there anyway for the message handlers on this tag using the system.util.sendmessage() function to initiate on the read/write/edit gateway instead of locally on the edge?
To summarize, I want to send a payload on tags from edge HMIs to an API on my read only gateway.
