Message not reaching session message handler
I'm sending a message from a button to a Session-scoped message handler, but the handler never fires.
Button runAction:
def runAction(self, event):
    system.perspective.sendMessage(self.view.params.MessageHandler,payload={},scope=self.view.params.MessageHandlerScope)
	system.util.getLogger('button').info('message sent to |' + self.view.params.MessageHandlerScope + '| '+ '|' + self.view.params.MessageHandler + '|')
Console output:
message sent to |Session| |LeaveSession|
Session Event > Message: LeaveSession:
def handleMessage(session, payload):
	system.util.getLogger('handler').info('message received')
The button logs that the message was sent, but the handler's 'message received' log never appears. am i missing something?
Unless it's something new to me, your syntax should be:
    payload = {},
    scope = 'view'
I'm pretty sure the scope argument is case sensitive.
fixed the syntax but that was not the main issue
message sent to |session| |LeaveSession|
as mentioned in the docs:
Send a message to a component message handler within the same session. This function cannot interact with Session Message Handlers configured in Session Events, even if the scope of session is specified.
instead i have to use
system.util.sendMessage(...)
