fpmi.gui.messageBox(“the response for the control is %s” % response )[/code]
The problem is that the message box that pops up says: "the response for the control is " instead of actually showing the message which is received after the execution of the stored procedure called by the select statement.
Looks like you want to perform a scalar query, that is- one that only returns 1 value. Otherwise, as is happening in this case, you’re going to get back a set of rows, or a single row with multiple columns. Your query is selecting ‘*’ after all, so the first thing to do would be to select the specific column you want, and then run it with the “fpmi.db.runScalarQuery” function instead. That function will return the first value it sees from the result set as an actual value that you can pass in to your message box.
Thanks.
The runScalarQuery works. The runquery with a ‘[0][0]’ option would also work in most cases, but it would not work if a timeout from the database occurs and nothing is returned or for some other reason nothing is returned.
Correct. Runquery returns a dataSet. A Null dataSet does not have a ‘[0][0]’ value. RunScalarQuery is the correct function to use if you expect a single item to be returned.
[quote=“qurban”]Thanks.
Thanks[/quote]
