Is it me or is there a problem with the Meter ccomponent?
When I drop a meter component in a window and then drag a tag to it, editing some of the properties doesn’t stick.
The meter has a lower bound and an upper bound. It defaults to 0 to 100.
If I set the lower bound to -100, it works correctly in the editor. Using one of simulated tags, it will swing between -100 and +100.
If I save the project, and recall it, the lower bound reverts to 0.
Should the change stick?
Launching the project in a window shows the lower bound is now 9.
The tick size sticks but the lower bound does not.
Version is 7.2.4
Dennis
