Does anyone have a method for adding tags to the historian and then managing them without having to go into each tag’s properties? I am using the XML import/export feature now. As far as I can see, tricks in XML editors is the best path but wanted to see what others are doing.
Take a look at system.tag.editTag. There is an example of how to enable history on the tag using this method.
Great, thank you, I will give this a try.
