Metrics not showing up on Ignition Designer and Ignition Web Interface
Dear All
Hello. I am working on a flow in NODE RED. The aim is to establish a reliable SparkplugB based MQTT communication. The initial flow is (@kcollins thank you for your help with this)
It does show all the metrics in ignition web interface and ignition designer
However I am working on a test case where my hardware interface does not support the sparkplug module and there is no way to install this through any other means.
This module is not supported
But Sparkplug plus module is supported
So making use of this module I made further modifications to my initial flow in the following ways
        "id": "e4168b47ecf2d348",
        "type": "tab",
        "label": "Flow 9",
        "disabled": false,
        "info": "",
        "env": []
        "id": "08c39838fbb9d8f6",
        "type": "function",
        "z": "e4168b47ecf2d348",
        "name": "Sparkplug",
        "func": "// Capture device name\n[\n    {\n        \"id\": \"21cb23aca25f8ff0\",\n        \"type\": \"sparkplug\",\n        \"z\": \"ec7476ef0136b446\",\n        \"name\": \"\",\n        \"broker\": \"tcp://localhost\",\n        \"port\": \"1883\",\n        \"clientid\": \"InductiveAutomation111\",\n        \"groupid\": \"Sparkplug Devices\",\n        \"edgenode\": \"Test6\",\n        \"version\": \"spBv1.0\",\n        \"enablecache\": \"false\",\n        \"publishdeath\": \"true\",\n        \"user\": \"admin\",\n        \"password\": \"__PWRD__\",\n        \"x\": 720,\n        \"y\": 440,\n        \"wires\": [\n            [\n                \"ef55783b857bf953\"\n            ]\n        ]\n    }\n]\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 740,
        "y": 240,
        "wires": [
                "575e65b7ee152614",
                "00911b8f2c513204",
                "ed4cfc1da8abe1f8",
                "15a23746c423d4cb"
        "id": "575e65b7ee152614",
        "type": "mqtt sparkplug out",
        "name": "",
        "topic": "spBv1.0/Sparkplug Devices/DBIRTH/Test6/Device4",
        "qos": "2",
        "retain": "true",
        "broker": "0d831bd9ba588536",
        "x": 950,
        "y": 300,
        "wires": []
        "id": "ed4cfc1da8abe1f8",
        "name": "",
        "topic": "spBv1.0/Sparkplug Devices/DDATA/Test6/Device4",
        "qos": "2",
        "retain": "true",
        "x": 950,
        "y": 360,
        "wires": []
        "id": "15a23746c423d4cb",
        "name": "",
        "topic": "spBv1.0/Sparkplug Devices/DDEATH/Test6/Device4",
        "qos": "2",
        "retain": "true",
        "x": 950,
        "y": 420,
        "wires": []
        "id": "0fc0476f4d01bc1a",
        "type": "function",
        "name": "DBIRTH",
        "func": "// Capture device name\nglobal.set(\"deviceId\", \"PLC9\")\n\nvar payload = {\n    \"timestamp\": msg.payload,\n}\nvar metrics = []\nmetrics.push({\n    \"name\": \"CurrentSeconds\",\n    \"value\": new Date().getSeconds(),\n    \"type\": \"int32\"\n},\n{\n    \"name\": \"Inputs/0\",\n    \"value\": true,\n    \"type\": \"boolean\"\n}\n)\npayload[\"metrics\"] = metrics\nmsg.payload = payload\nmsg.topic = `${global.get(\"deviceId\")}/DBIRTH`\nflow.set(\"running\", true)\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 600,
        "y": 300,
        "wires": [
                "08c39838fbb9d8f6"
        "id": "b0e03cda4217715d",
        "type": "link in",
        "name": "Rebirth",
        "links": [
            "0f808b57f9f93aa6"
        "x": 425,
        "y": 240,
        "wires": [
                "0fc0476f4d01bc1a"
        "id": "03be983f6938c2cf",
        "type": "inject",
        "name": "Update",
        "props": [
                "p": "payload"
                "p": "running",
                "v": "running",
                "vt": "flow"
        "repeat": "1",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 400,
        "y": 360,
        "wires": [
                "0b8522cb6c7a0fba"
        "id": "0b8522cb6c7a0fba",
        "type": "function",
        "name": "DDATA",
        "func": "if (!msg.running) {\n    return null;\n}\nvar payload = {\n    \"timestamp\": msg.payload\n}\nvar metrics = []\nmetrics.push({\n    \"name\": \"CurrentSeconds\",\n    \"value\": new Date().getSeconds(),\n    \"type\": \"int32\"\n    },\n    {\n    \"name\": \"Inputs/0\",\n    \"value\": true,\n    \"type\": \"boolean\"\n}\n)\npayload[\"metrics\"] = metrics\nmsg.payload = payload\nmsg.topic = `${global.get(\"deviceId\")}/DDATA`\nreturn msg;\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 610,
        "y": 360,
        "wires": [
                "08c39838fbb9d8f6"
        "id": "5a73da41d3fc779e",
        "type": "function",
        "name": "DDEATH",
        "func": "var payload = {\n    \"timestamp\": msg.payload,\n}\nmsg.payload = payload\nmsg.topic = `${global.get(\"deviceId\")}/DDEATH`\nflow.set(\"running\", false)\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 600,
        "y": 420,
        "wires": [
                "08c39838fbb9d8f6"
        "id": "ed3cc764add1f66f",
        "type": "inject",
        "name": "Stop",
        "props": [
                "p": "payload"
                "p": "reset",
                "v": "true",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 390,
        "y": 420,
        "wires": [
                "5a73da41d3fc779e"
        "id": "e790dd384ea25177",
        "type": "inject",
        "name": "Start",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 390,
        "y": 300,
        "wires": [
                "0fc0476f4d01bc1a"
        "id": "f69198aa5bfad8e4",
        "type": "debug",
        "name": "sparkplug debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 970,
        "y": 540,
        "wires": []
        "id": "0f808b57f9f93aa6",
        "type": "link out",
        "name": "Rebirth",
        "mode": "link",
        "links": [
            "b0e03cda4217715d"
        "x": 1125,
        "y": 180,
        "wires": []
        "id": "00911b8f2c513204",
        "type": "switch",
        "name": "Route Outputs",
        "property": "topic",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "rebirth",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 940,
        "y": 180,
        "wires": [
                "0f808b57f9f93aa6"
        "id": "e0a15ddcc9f60832",
        "type": "mqtt sparkplug in",
        "name": "",
        "qos": "2",
        "x": 490,
        "y": 600,
        "wires": [
                "85d8379ae0adeb7f"
        "id": "85d8379ae0adeb7f",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 970,
        "y": 600,
        "wires": []
        "id": "7027f258c5c317e6",
        "name": "",
        "qos": "2",
        "x": 490,
        "y": 660,
        "wires": [
                "4256bfcdab90af27"
        "id": "4256bfcdab90af27",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 970,
        "y": 660,
        "wires": []
        "id": "2afbb4af8fad30d7",
        "name": "",
        "qos": "2",
        "x": 490,
        "y": 720,
        "wires": [
                "db8fe382d45b495a"
        "id": "db8fe382d45b495a",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 970,
        "y": 720,
        "wires": []
        "id": "0d831bd9ba588536",
        "type": "mqtt-sparkplug-broker",
        "name": "Local Host",
        "deviceGroup": "Sparkplug Devices",
        "eonName": "Test6",
        "broker": "localhost",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "enableStoreForward": false,
        "primaryScada": ""
and
this way
        "id": "f35f22ba8892e611",
        "type": "tab",
        "label": "Flow 8",
        "disabled": false,
        "info": "",
        "env": []
        "id": "9fcc8012c1be937e",
        "z": "f35f22ba8892e611",
        "name": "",
        "topic": "spBv1.0/Sparkplug Devices/DBIRTH/Test5/Device3",
        "qos": "2",
        "retain": "true",
        "x": 910,
        "y": 360,
        "wires": []
        "id": "4890f7bd3bb383a5",
        "name": "",
        "topic": "spBv1.0/Sparkplug Devices/DDATA/Test5/Device3",
        "qos": "2",
        "retain": "true",
        "x": 910,
        "y": 420,
        "wires": []
        "id": "ddd2f668a7c4f2f2",
        "name": "",
        "topic": "spBv1.0/Sparkplug Devices/DDEATH/Test5/Device3",
        "qos": "2",
        "retain": "true",
        "x": 910,
        "y": 480,
        "wires": []
        "id": "f330bbb07630dac7",
        "type": "function",
        "name": "DBIRTH",
        "func": "// Capture device name\nglobal.set(\"deviceId\", \"PLC8\")\n\nvar payload = {\n    \"timestamp\": msg.payload,\n}\nvar metrics = []\nmetrics.push({\n    \"name\": \"CurrentSeconds\",\n    \"value\": new Date().getSeconds(),\n    \"type\": \"int32\"\n},\n{\n    \"name\": \"Inputs/0\",\n    \"value\": true,\n    \"type\": \"boolean\"\n}\n)\npayload[\"metrics\"] = metrics\nmsg.payload = payload\nmsg.topic = `${global.get(\"deviceId\")}/DBIRTH`\nflow.set(\"running\", true)\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 560,
        "y": 360,
        "wires": [
                "9fcc8012c1be937e",
                "5cac959b09503939",
                "1d17a2f386fd0479"
        "id": "2c00a2d5d54e004e",
        "type": "link in",
        "name": "Rebirth",
        "links": [
            "efeaa1159390bc88"
        "x": 385,
        "y": 300,
        "wires": [
                "f330bbb07630dac7"
        "id": "24764db11096a601",
        "type": "inject",
        "name": "Update",
        "props": [
                "p": "payload"
                "p": "running",
                "v": "running",
                "vt": "flow"
        "repeat": "1",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 360,
        "y": 420,
        "wires": [
                "cdab6a55c9c1aa86"
        "id": "cdab6a55c9c1aa86",
        "type": "function",
        "name": "DDATA",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 570,
        "y": 420,
        "wires": [
                "4890f7bd3bb383a5",
                "5cac959b09503939"
        "id": "ce5339b610f15f4a",
        "type": "function",
        "name": "DDEATH",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 560,
        "y": 480,
        "wires": [
                "ddd2f668a7c4f2f2",
                "5cac959b09503939"
        "id": "502478a4d21792c2",
        "type": "inject",
        "name": "Stop",
        "props": [
                "p": "payload"
                "p": "reset",
                "v": "true",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 350,
        "y": 480,
        "wires": [
                "ce5339b610f15f4a"
        "id": "485d12074928bcfa",
        "type": "inject",
        "name": "Start",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 350,
        "y": 360,
        "wires": [
                "f330bbb07630dac7"
        "id": "5cac959b09503939",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 930,
        "y": 600,
        "wires": []
        "id": "efeaa1159390bc88",
        "type": "link out",
        "name": "Rebirth",
        "mode": "link",
        "links": [
            "2c00a2d5d54e004e"
        "x": 1085,
        "y": 240,
        "wires": []
        "id": "1d17a2f386fd0479",
        "type": "switch",
        "rules": [
                "t": "eq",
                "v": "rebirth",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 900,
        "y": 240,
        "wires": [
                "efeaa1159390bc88"
        "id": "5786fdc09e3ca0e4",
        "name": "",
        "qos": "2",
        "x": 450,
        "y": 660,
        "wires": [
                "b861e09d17229556"
        "id": "b861e09d17229556",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 930,
        "y": 660,
        "wires": []
        "id": "2981a45ca47ef085",
        "name": "",
        "qos": "2",
        "x": 450,
        "y": 720,
        "wires": [
                "f5c4857d1ddb539f"
        "id": "f5c4857d1ddb539f",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 930,
        "y": 720,
        "wires": []
        "id": "cb790570b5f4bab3",
        "name": "",
        "qos": "2",
        "x": 450,
        "y": 780,
        "wires": [
                "34858db4fc610cb9"
        "id": "34858db4fc610cb9",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 930,
        "y": 780,
        "wires": []
        "eonName": "Test6",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "primaryScada": ""
The problem however is that the input metrics no longer show up in the ignition designer or ignition web interface
Edge Nodes - Sparkplug Devices - Test 5 and Test 6
They only show two folders : Node Control and Node Info but none of the input metrics. I would like to request for help in this regard. Thank you.
Could you format the code in your question as code? Hit the πŸ–‰ edit link and then select a block of code and press the </> button to format it. It will preserve indentation and do some syntax highlighting for you.
You can also use the :gear:, Hide Details to collapse each block. This will make it much easier to navigate your question.
Thanks.
I use this module in 50 plus devices (pi's) using spark plug B. What makes you say its not supported ?
My device only runs on NODE RED v1.1.0 and it cannot be updated nor be connected to the internet. I have always installed modules onto the device NODE RED interface via the memory card or USB. I have tried 18 different installations for the module and it did not work. If it did work, I would not make this post in here.
Understood, just trying to establish what the issue is as your first pics show it as working. The SD card can be removed from the device that cant go online, put in a device that can go on line, updated then swapped back over.
Edited to say, I'm making an assumption (probably wrong) that your using Pi's.
