When configuring outgoing connections in Gayway Network, if ssl is configured, the default port is 8060. If ssl is not configured, what is the default port, or which attribute should be configured in data/gatway.xml
If you are not using ssl, the default gateway network port is 8088 (the standard Ignition http port).
My configuration here does not work, no matter the port is 8060 or 8088
See if there are any error messages in the gateway log on the outgoing side. If so, post them here so we can take a look.
It’s OK. Thank you
