Micro820 Modbus mapping
Hi all, I am trying to connect Allen Bradley Micro820 to my ignition with Modbus TCP
Do you know how I can Config Modbus mapping
I have 4 digital input and 4 digital output in the device nothing else
would you please help if you can?
You don’t have to use the map…
I don’t suppose the micro820 shows the modbus equivalent in its ladder editor…
youll have to map the plc tags to ingition tags using an opc path
https://docs.inductiveautomation.com/display/DOC81/Modbus+Addressing
Here’s a great place to start - Modbus
If your are just trying to get the PLC “Tags” into Ignition, I can recommend another easy and efficient way to get that job done.
By using a Maple Systems MQTT Gateway at a cost of $390.00 USD. you can directly communicate with Ignition. If you setup Sparkplug B it works flawlessly!
Yes its work thanks
